Apexi Power FC Vs. Apexi Power FC D-Jetro
Okay so the regular power FC uses the MAF sensor, while the D-Jetro uses a MAP Sensor. I was wondering since I am leaning towards the D-Jetro, is this a complete plug and play piggyback computer even though it replaces the MAF sensor? Is there any other wiring that has to be done in order for this conversion to work? I have been searching for a while and can't seem to come up with an answer.
Thanks, Zach |
Also, the D-Jetro has another sensor kit that you must use for the D-Jetro to work. I am sure that this sensor kit is what takes place of the MAF sensor. I am just checking with other fellow members to make sure I am right.
Zach |
Yes you are right it taps into your intake manifold.
Tap the intake for the sensors, run some more wires, and you done.
| All times are GMT -7. The time now is 12:29 AM. |
