best turbocharger?
Lol, this may not be 100% true. The best turbocharger for the KA is the one that will give you what you want out of it. Generally, a larger turbo will produce more power, but take longer to spool. A smaller turbo will spool faster, but you may not get as much power out of it, making it less efficient.
If you DO get a turbo that is around the size of "Blowzilla"(.70 a/r, 61mm inducer 65 lbs/min 832cfm flow, T3 turbine, .63a/r or .82a/r housing), you may also want to consider ball-bearing. This will decrease spool time.
Depending if you want your car for drag, drift, street, whatever; that will decide what turbo is best for YOUR KA.
Originally posted by chiroke
depends on wut u want if i had the money i would get a gt35r
this thread is retarded, why you you ask someone "hey, what turbo should i get for my car?"
you gotta do research man, forum suggestions are a great start, but you gotta put the effort in to help yourself
Bigger Turbo = Bigger Lag.
an GT28r is good enough.
..but Turbodyne sells "Lag Free" Turbo.
It's bull**** cause my friend has one running on his Evo..and ****, they needed to research that **** more.
Pretty much this is a waste of bandwidth......
Alot of guy's that go KADET usually chose the T28 over the T25. For the cost they arent to much different, and the T28 has an increased CFM rating than the T25. Basically it's a little better which makes it the bigger bang for your buck over a T25.
It's not an all out drag turbo by any means just a really good turbo that makes decent power. Especially since it came on every RB20det.
BILLYhoang
Feb 10, 2012 11:39 PM
Andrew C.
Mar 15, 2005 01:48 PM
