CLUTCH PROBLEMS please read and shed light on subject
Old 01-08-2007, 05:50 PM
2fast4y0u's Avatar
Exclamation CLUTCH PROBLEMS please read and shed light on subject
ok as some of you know i have had major clutch problems...
here is my orginal post about this on going problemi finally got my car running. i put in a new act clutch like i had last year and a fidnaza lighten flywheel.
when i get into boost in second, third, or fourth gear the clutch just lets go and the revs take off.
i bled the clutch 3 times now and still the same thing.
everything is tourqed to factory specs like it should be.)
so, long story short. i took everyones advise on things to do with this problem.
up to date here is a list of everything i have done...
new slave cylinder
bled clutch at least 50 times(no joke)
check all lines and fittings
fluid is topped off and good
LAST NIGHT(1-7-07) i pulled the trans and found out the clutch fork wasnt even hooked up! neat!
so, now im back to step one again. can will drive down the road but its like the clutch is slipping out under high rpm's. as soon as i get into about mid range of the gear the rpm's take off like crazy. i inspected the clutch and flywheel when i had the trans out last night and all that is perfect. i dont have any fluid leaks or loose fitting, also there isnt any oil leaking from the rear main seal.
i looked up the ft lbs. of torque specs for the ACT clutch i have and its 362 ft lbs... unless adding 264 cams and a port and polish can add 150 ft lbs of torque then i know i am just fine with that.
so any help or info would be greatly apreciated. my car hasnt seen the road in working condition in over 14 months now.
Thanks in advance
Jay
2fast4y0u is offline
Old 01-08-2007, 06:34 PM
v8killa's Avatar
do you still have the clutch damper if so rip that **** out and check the master cylinder for leaks sometimes itll leak and lose pressure.
v8killa is offline
Old 01-08-2007, 06:37 PM
fastharry's Avatar
what does the fly wheel look like. maybe another cut will help it. maybe something with the throw out bearing.
fastharry is offline
Old 01-10-2007, 07:23 AM
2fast4y0u's Avatar
no damper... it was an auto to begin with. the car worked just fine last year.
fly wheel looks great its brand new fidanza lightwieght
Old 01-12-2007, 06:37 AM
2fast4y0u's Avatar
please help me here....i need to drive my car
Old 01-12-2007, 08:19 AM
v8killa's Avatar
is there a leak from the master, also the slave could be bad. but that really wouldnt make the clutch slip.
HAS TO BE ONE OF THESE 4
DEFECTIVE DISK/PP
OIL LEAK FROM MAIN SEAL ONTO CLUTCH
OR
BAD MASTER CYLINDER/NEEDS BLEEDING
GOOD LUCK
v8killa is offline
Old 01-12-2007, 08:21 AM
v8killa's Avatar
sorry I just re-read your first post I know your problem
Same thing happened to me
You have to adjust your clutch!!!
Call me and Ill explain..
Mark
973-652-4318
v8killa is offline
Old 01-12-2007, 09:43 AM
2fast4y0u's Avatar
pm sent
you can email me at jayyaggie@gmail.com
or call me at 630-742-2502
thank you so much...
Jay
Bryan
02-20-2007 11:42 AM
dave8775
04-21-2004 05:25 PM
project yak
02-08-2004 07:36 AM
DCTperformance
03-20-2003 03:28 AM
thedaemon
11-02-2002 09:46 AM
Quick Reply: CLUTCH PROBLEMS please read and shed light on subject
