-   Turbo Motor (https://www.s-chassis.com/forums/turbo-motor-12/)
-   -   Building SR20 for 375 hp - Your advice? (https://www.s-chassis.com/forums/turbo-motor-12/building-sr20-375-hp-your-advice-24502/)
KMag Jul 12, 2005 03:06 PM
Hi everyone. My first post to this forum. I'm a Mazda guy, but I'm now gettting into a Nissan for the first time. My stepson, military man, just came back from oversea's for a 30 day leave has a 240sx. To make a long story short, he broke a piston and now has a replacement junk yard engine. I'm going to build the other engine for him while he's gone. Also going to put together some upgrades for him on other things. The broke motor had been bored to 85.5. It's going to rebored and sleaved for a larger piston. What size would be recommended, 88 or 90 mm?
Any comments? Let me say that it's going to be a "built" engine. Not going to cut many corners. Thanks
Slidin240 Jul 12, 2005 03:14 PM
first off :wave: welcome to the forums.
2nd. since your going to build the motor up good, i think you should use bigger pistons, meaning you'll need it to be resized to 90mm. u only want 375HP? :laugh:
if you build the SR properly you'll be able to push alot more then that.
Good luck! :thumb: and keep us informed of the project.
BTW PICS!!
KMag Jul 12, 2005 03:21 PM
Thanks for the welcome!
Well since I'm unfamiliar with the potential of this unit, we were discussing the 375 range. It's going to change with what we do to it. I'm in my first phase of research. First I wanted to set the piston size. I don't know much about these sleaved blocks. What would be the largest safe piston size? 90mm?
I have a lot more to do.
Thanks KMag
Slidin240 Jul 12, 2005 09:44 PM
i havent built an SR20 (cus i took the KADE-T route) but im guessing that bigger is better if your going to build up the rest of the motor. I kno others will post bout the best size and such.
There have been SR20's that were built and were able to hit 600+hp and depends on Turbo and how much boost ull be running. But so much HP isnt needed. depends on plans for the car. 375-400 HP sounds good thats my goal rite now with KA24DE-T
KMag Jul 13, 2005 06:05 AM
Thanks Slidin240. I think I'll just work around the 375 to 400 range. He's only going to drive it when he comes back to the states, which is only a couple times a year. I know he wants something that's streetable, not too much over the top.
Anyone else have any info the max safe size piston?
Thanks
revolutionz_s13 Jul 13, 2005 09:40 AM
well, if you have someone bore it and sleeve it, you can slide 90mm pistons in, which will make the motor and SR22. I believe darton makes 90mm sleeves that will work for the SR. check out http://www.lsauto.com/default.asp
KMag Jul 13, 2005 09:49 AM
Thanks revolution. I take it that it would be a 2.2 liter with 90 mm pistons? I'll check out SR.
Now, on to rods!
KMag
Slidin240 Jul 13, 2005 10:44 AM
check this site out, they have everything you can want for this motor and they are very good people and easy to do business with.
www.heavythrottle.com
KMag Jul 13, 2005 11:59 AM
Thanks everyone for the links!
KMag
Slidin240 Jul 13, 2005 12:15 PM
heres a couple more:
http://www.jgycustoms.com/
http://www.enjukuracing.com/
http://www.aspecproducts.com/
also heres the FSM for the SR20
http://www.zeroyon.com/TheSite/techservice.html
KMag Jul 13, 2005 12:27 PM
Thanks Slidin!
You are very helpful!
KMag
Slidin240 Jul 13, 2005 01:02 PM
like it says under my SN, im here 2 help :thumb:
- Golam
bottombunk Jul 16, 2005 07:39 AM
you should do the next size up. not the biggest. it doesnt leave much room for rebuild if something happens again. if you do the larger then resleeving would be in order if something goes down. just build it to min. size then get a turbo thats appropriate to your app.
KMag Jul 16, 2005 09:57 AM
Thanks bottombunk,
That's what we came to the conclusion too. Looks like we're going to resleave, use 88mm pistons. That would give us some room for rebore later. We're still trying to decide which brand piston and chromealloy rods to use.
We've got several requests out to several different shops for pricing. I hope to hear back from them next week so we can send the block out to get the sleaving and boring done.
Thanks for the info. KMag
bottombunk Jul 16, 2005 03:31 PM
ross and pauter if you can afford them
