dreaming agian?
Old 11-02-2006, 09:20 PM
cheapster757's Avatar
dreaming agian?
finally got $ saved up. looking to turbo my 92'.. like the other 53423 million. i have a 5-speed ka24de with 120,000 on it.
i dont have much knowlegde so correct me if im wrong about what i need. i would also app. it if i could get a rough estimate on cost and best sites/brands to go by? what can i get from ebay?
and since the high mileage what should i do? internals wise? pistons?
-bov
-turbo manifold
-downpipe
-fmic
-370cc SR injectors?
-emanage
-msd, im thinking?
im shooting for the 200-250 whp range
i know i need to sreach, and i am. i just cant seem to find the info i need.
cheapster757 is offline
Old 11-02-2006, 10:49 PM
check ur compression rate to determine if u need new internals or not...if that checks out ok then ur ok for mild boost setup..
get the turbo outlet/downpipe from ebay
get the greddy m-spec fmic, its only like 400 which is amazingly cheap for a good name brand
dont forget about a turbo, wastegate, fuel pump, boost controller...and thats all i can think of right now
emanage isnt necessary, just get an safc and a good tune
msd? u dont need ignition crap unless u got extra money
oh and metal headgasket would be helpful..
motegineon is offline
Old 11-03-2006, 11:33 AM
what are some safe internal repairs i should consider?
and as far as the turbo, wastegate, and fuel pump, wheres the bast place to look? is that pretty much all i will need to push about 250whp(including the other parts listed)?
and how much money am i looking to spend on this? roughly
Old 11-03-2006, 03:41 PM
oh and dont forget about oil/coolant lines for the turbo..
enjuku racing/jgycustoms/ebay/option imports ect just google whatever product ur looking for and find the best price
well if ur gonna do internal work u may as well do it all while u got it apart..but if ur only lookin for 250hp then u dont need internals as long as ur compression check comes out ok.
Old 11-03-2006, 04:54 PM
tehott240's Avatar
if i was u i would get bigger injectors.
tehott240 is offline
Old 11-03-2006, 06:33 PM
bigger than the SR ingetors i mentioned?
Old 11-03-2006, 09:36 PM
KerosineK's Avatar
SR injectors are fine. The most important part though is definitely tuning. Most KA's blow up due to people skimping on the tune. Take it to a reputable shop and have them tune it, dont just order a JWT ECU and think you are good to go because those things have some crazy settings...
KerosineK is offline
Old 11-03-2006, 11:00 PM
Old 11-04-2006, 05:15 AM
great. thanks for the info! what turbo should i get if im trying to get about 250whp?
Old 11-04-2006, 06:51 AM
s14 t28 bb will do fine, find one for around 300bucks and good to about 16psi
Old 11-04-2006, 01:34 PM
KerosineK's Avatar
You dont want to run 16 PSI on a KA with stock internals though. While it may last for a little while, it will go one day. I would run .5 BAR (~7 PSI) MAX on a KA with stock internals....
Old 11-04-2006, 04:43 PM
yea i never said run that high, and u can run 10psi easy with a tune
Old 11-04-2006, 07:25 PM
wheres the best place to bag that sucker?
Old 11-04-2006, 07:27 PM
how much money am i looking to spend on this all together? roughly
Old 11-04-2006, 09:40 PM
check on zilvia.net and other large 240 forums in the for sale section, just search for it
Quick Reply: dreaming agian?
