I cant get any tech info from people here.
Hey, Im not trying to complain but it seems all the questions that get answered on here are "how hard is it to swap this" or "will this work if". I need specs for a rebuild but I cant get any. I know there has to be someone on here he has info. Or does someone atleast know a site?
what was your question again? something about a rebuild?
This isn't exactly the most "technical" 240 forum out there. You try asking the question on other nissan/240 forums?
Any recommendations? I also have alot of technical Q's.
There's almost nothing you can't find searching on freshalloy.
try NICO or Fresh Alloy. make sure you SEARCH on both forums before you ask questions.
Basically while I wait for the harness to come in I want to put in cams so i need torque specs for the caps and sprockets. I also need to minimun maching for the flywheel, the torque specs for the flywheel and pressure plate. Over winter I want to rebuilt it so I will need all engine specs. What I really need is a manual from Austria or another english speaking country that had sr20s.
Thanks for the links guys. The SEARCH for knowledge continues...:p
Thank you very much for that links. Thats all the info I need.
