interchangable parts for starter
is there interchangeable parts to rebuild a starter from a sr20det. would a sentra se-r fit and tha KA fit. need help to find parts
what i meant is that do the sr20de starter have interchangeable parts with the sr20det starters or that KA starters. which could be rebuildable when there are unreliable issues.
the rwd sr20de and rwd sr20det have the same starter... i cant imagine the fwd would work though
the problem is searching for the rwd SR20de in the states. obviously its the same but i havent check out if the fwd sDR20de is the same. part numbers for a starter dont match over here.
Originally posted by s13silvia123 the problem is searching for the rwd SR20de in the states. obviously its the same but i havent check out if the fwd sDR20de is the same. part numbers for a starter dont match over here. |
