which intercooler???
So if i get an SR20 from an S14, and put it in an S13, which iFMIC would I get, One for the S13, or the S14???
Good question!??? Are the intercoolers engine specific or car specific?:dunno:
youd probably need to get the s13 kit. both motors are basically the same besides the vvt and t28 but i still think you would need the s13 piping so the pipes could route through the bumper better.
id order the s13, the hotpipe is gona be the thing that needs to be s14 specific, i duno about the rest of the piping though..
ya s13 cause the pipes have to run threw the s13 body.
For S14 engine in S13 car, select S14 FMIC Kit with S13 Hot pipe. The hot side will need custom modification because the S14 hot pipe passes through the frame opening on S14, which does not exist on S13.
For S13 engine in S14 car, select S13 FMIC Kit with S13 Hot Pipe. (found this on heavythrottle.com) |
has anyone use this greddy spec-m fmic yet? check out this link.......... http://cgi.ebay.com/ebaymotors/SR20D...mZ320073874007
linky no worky
What about an RB26 into an S13. what would i use for that???
if you have a rb in s13 or s14 you just gonna have to get extra pipings and do soem fab work to it to fit how you want it to be,here is that link i found........... http://cgi.ebay.com/ebaymotors/SR20D...mZ320074254348
and i wanted to know too i got a s14 and plan on putting an s13 sr20 and i wanted to get a bov kit so its all bolt on should i get it for a s14 or s13?
Phase2motorsports say that if you get it to match the body, it will fit pretty good, except the coldpipe might need some adjusting.
