-   Turbo Motor (https://www.s-chassis.com/forums/turbo-motor-12/)
-   -   just installed Oil Cooler ! will this slow my oil pressure to the turbo? (https://www.s-chassis.com/forums/turbo-motor-12/just-installed-oil-cooler-will-slow-my-oil-pressure-turbo-16661/)
ass15 Oct 18, 2004 11:40 AM
i just installed an oil cooler from Mistubishi turbo conquest.... was wondering will the oil pressure change after the oil cooler going to the turbo?
also how much extra oil will it take now.
thx in advance peep...
sr20hardbody Nov 6, 2004 07:37 PM
you shouldn't loose any oil pressure. But if you do loose iol presssure it should only be by 1psi or 2psi tops
hitokiri_808 Nov 19, 2004 10:06 PM
pressure shouldn't drop. as for the oil, just add how much oil would fit into the cooler. you could probably google it to find the coolers capacity.
Project Cheap13 Nov 20, 2004 06:33 AM
Why would you install something if you didnt know how it worked?
ruthlesstyper Dec 15, 2004 09:42 PM
Didnt the conquest come with a stock oil cooler?
hitokiri_808 Dec 17, 2004 12:15 AM
pretty sure he installed the conquest's oil cooler into his 240.
