more boost?
hey guys, im sure this is asked a lot, but i couldnt really figure out what to search for. sorry :dunno:
what im wondering is, i'm buying a 240 this week, its got an SR w/ T28, stock injectors, ect. it also has an SAFC-II and AVC-R to run more boost, would all i have to do be upgrade the injectors and fuel pump, then turn up the SAFC-II and AVC-R ???? the owner of the car told me that a T28 would do fine at 14 psi, is this true? thanks, Greg |
fuel pump, injectors, and a FMIC are necessary
16psi max on the t28, although i run 17psi i wouldnt recommend it.. you need a tune after your get the injectors and fuel pump, do not try to up the boost and whatnot until it gets on a dyno and is tuned.. |
is it s14 sr?
it wouldnt matter what motor he has, its got the t28bb turbo so either way its the same.
