motor differences s14 s13 DOHC
Old Jan 20, 2005 | 08:39 PM
twitch24's Avatar
here is my question... i have a 1991 240 sc se coupe 5 speed DOHC..and i bought a junk motor from a 1995 240sx DOHC...my plans are to forge the pistons and get the rods and crank treated and i am going to bolt of a turbo kit... i want to get about 400-500rwhp out of it...but here is my question...what are the dirrerefces between the motors and if there are any how can i fix this prob the easiest way to swap it in????(by the way the motors are the exact same)thanks.
Old Jan 20, 2005 | 10:13 PM
Catharsis's Avatar
the 95 KA is obdI and has cams with less duration and higher lift..for info on building to 500whp check out www.ka-t.org
Old Jan 21, 2005 | 01:56 AM
ArticDragon's Avatar
95 KA also has higher compression.
Old Jan 21, 2005 | 10:43 AM
Catharsis's Avatar
no it doesnt
Old Jan 21, 2005 | 01:34 PM
You sure? I read on a specs sheet the compression of 95+ KAs are higher than 91-94 KAs, 9.5:1 compraed to 8.6:1 respectively.
91 Specs
http://www.socal**********/faq/1991.html
95 Specs
http://www.socal**********/faq/1995.html
I'm guess ing that's why the 95+ KAs are making the same power as the 91-94 KAs since they have more conservative cams and high compression.
Old Jan 21, 2005 | 07:26 PM
ph34r's Avatar
the 89-90 KA24E has the 8.6:1 compression and a single overhead cam. 91 on has 9.6:1 compression and dual overhead cams.
Old Jan 21, 2005 | 07:47 PM
Project Cheap13's Avatar
The Ka24e can either have 8.6:1 or 9.1:1
(depending on year)
Just a little FYI
Old Jan 21, 2005 | 08:19 PM
I'm talking DE, not E. I know the E has 8.6:1. but also the 91-94 DE engines.
Old Jan 21, 2005 | 09:23 PM
Catharsis's Avatar
no the s14 has a longer durationm on the cams even though the lift is lower
Old Jan 23, 2005 | 04:26 PM
twitch24's Avatar
alright ........all i want to know is if there is any wiring problems to where i am going to have to swap harnesses(that is a pain in the ***) cuz i am going to spend alot on this motor and if a cant just bolt in the new motor and go then i am going to junk the block...
Old Jan 23, 2005 | 08:52 PM
Catharsis's Avatar
shouldnt be too hard to do no harder than a sr swap
Old Jan 25, 2005 | 09:16 AM
twitch24's Avatar
this is the reason that i am not doing an sr swap is because of the wiring.......i want to know if i can bolt on parts from a 91 to a 95.....cuz i am geting all sorts of new parts...pretty much a whole new motor...intake turbo al new forged pistons....and everything inbetween.just please tell me if i cant do this.....cuz t will save me alot of work and alot of $$.by the way i am doing all of the work by myself...and i dont have the most $$ so i have to be careful on what i buy and where i get it from...thanks
Old Jan 25, 2005 | 04:47 PM
twitch24's Avatar
yea dont worry... i think i got it all figured out...muhahaha ka-t power
Old Feb 9, 2005 | 10:32 AM
cleveland180's Avatar
If the motors are so similair, then why does greedy make a turbo kit for only for the '95 and up.
Old Feb 9, 2005 | 02:00 PM
OBD-II. KAs 96 and up, including some 95s have OBD-II which means more sensors.
