-   Turbo Motor (https://www.s-chassis.com/forums/turbo-motor-12/)
-   -   Oil Feed, Return lines? (https://www.s-chassis.com/forums/turbo-motor-12/oil-feed-return-lines-17873/)
lrb_2000 Nov 30, 2004 11:53 PM
I'm new to turbos... i'd like to know really quick, what role the "Oil Feed, and Return lines"... like if I were to go for a custom turbo setup in the future.
hitokiri_808 Dec 2, 2004 05:52 AM
ummm. the oil feed lines run oil to the turbo and the return lines return the oil.
or were you asking about how you would run the lines with a custom turbo?
lrb_2000 Dec 2, 2004 10:12 AM
yeah, how would you run these... where do they "tap" into, or whatever..
ILLICON2003 Dec 2, 2004 11:17 AM
on my civic you put a 3 way tee fitting on where the low oil indicator light sat at..that was the feed line. for the return, you'd drill holes in the oil pan and mount the flange there. No idea how you'd do it on a ka though. good luck
