S14 T28 on CA18DET
I know Catharsis can help me on this, but what is necessary for running the S14 T28? What lines need to be modified? Is the S14 T28 or S15 T28 easier to install? Thanks...
they are both the same turbo
and its one of those things you will need to buy and then test fit... grab a few extra gaskets cause you will need to space it and grind for some clearance |
| All times are GMT -7. The time now is 02:10 AM. |
