spare cylinder head???
I have a spare cylinder head from my other ka24de, its separated from the block which i do not have anymore. im going to turbo my 240 soon but i wanted to ask what suggestions i could do with my spare head? if i port and polish it wouldnt i have to do that to the block too? help me out thanks.
What on the block would you port? The water and oil ports? No you do not need to "port and polish" your block. When you have a head portED and and polishED they expand and clean up the ports above the valves for increased flow.
Originally posted by vbgambini
see so i do have to bore it out on the block right? what could i do to the head without touching the block for turbo?
hrt is like 20 mins away from me here. pricing dosent look too bad on handcraftedracing.com. i think like
Valve Job (3 Angle)
2 Valves/Cylinder
4 Cylinders $90
6 Cylinders $130
3 Valves/Cylinder
4 Cylinders $130
6 Cylinders $190
4 Valves/Cylinder
4 Cylinders $170
6 Cylinders $250
Stage One Port and Polish
2 Valves/Cylinder
4 Cylinders $70
6 Cylinders $105
3 Valves/Cylinder
4 Cylinders $105
6 Cylinders $160
4 Valves/Cylinder
4 Cylinders $140
6 Cylinders $210
What do they mean 2valves/cylinder then 3 valves/cylinder. wont i wanna do all of them?
Valve Job (3 Angle)
2 Valves/Cylinder
4 Cylinders $90
6 Cylinders $130
3 Valves/Cylinder
4 Cylinders $130
6 Cylinders $190
4 Valves/Cylinder
4 Cylinders $170
6 Cylinders $250
2 Valves/Cylinder
4 Cylinders $70
6 Cylinders $105
3 Valves/Cylinder
4 Cylinders $105
6 Cylinders $160
4 Valves/Cylinder
4 Cylinders $140
6 Cylinders $210
it means how many valves there are per cylinder, the KA24DE has 16 valves, two exhaust and two intake for each cylinder, so thats 4 valves/cylinder, so according to that chart:
3 Angle valve job- $170
Stage one P&P-$140
Stage one P&P-$140
