-   Turbo Motor (https://www.s-chassis.com/forums/turbo-motor-12/)
-   -   SR20 Red-Top Starting Problems... (https://www.s-chassis.com/forums/turbo-motor-12/sr20-red-top-starting-problems-19397/)
NiNJA323 Jan 20, 2005 09:13 PM
Well I was driving around and my SR20 just dies on me.. I was only going like 20mph and it just cuts off...
I try to crank the car back up, it keeps turning and turning but won't turn over... So first thing I do is check all the fuses, no blown fuel pump fuse. I had one and that was the Eng. Cont. one (25-A fuse), I replaced that and still the same thing..
I have a Walbro 255lph fuel pump, and now when I turn the ignition with the key in, you can't hear the fuel pump coming on like usual. My S-AFCII would power up when the key was turned but now it just stays off..
I doubled checked all my fuel lines, and I/C lines for any vacuum leaks but nothing. I know my car is running rich so do you think my spark plugs could be fouled out? I would check but I don't have the tool for it over at my parent's house. But the thing is, my S-AFCII isn't powering up so I was thinking it could be a loose ECU connection or just that my ECU went bad?
What else could I look/check for?
Jimz389 Jan 21, 2005 03:38 AM
You should check the battery voltage with a meter, it could be your alternator which just died on you.
JZ
NiNJA323 Jan 21, 2005 10:50 AM
JZ
It's not my alternator.. I get a charge to my battery.. All my interior lights/headlights, brakelights, etc.. come on. Even my radio comes on.
