SR20DET TPS Question???????
Ok heres the deal........ First of i have a red top SR20 in my car and for the past mont or so i have been running super rich and getting a screaming noise from the turbo. Also every time i would get into boost the car would loose power. when just doing normal driving when i would come to a stop the car would bog down and stall...
So i have a friend that is running the same set up as i am and his motor would not rev over 4000 rpms so they unpluged his TPS and it cleaned up and ran great. Its been about 18 months and his car still runs good and hes runing 12 psi and gets 27 miles to the gallon....
So we were working on my car and he told me to unplug mine and sure enough it cleaned up the running rich problem and the turbo noise went away and i went from 12 miles to the gallon to 26 miles to the gallon. With all my problems gone....
My Question is should i replace the TPS or just run without it? if i should replace it is there a USDM version that will work with it? Will running with out the TPS cause any other problems? Like i said the car runs great now i just want to know if i should replace out of fear of breaking something else.
