-   Turbo Motor (https://www.s-chassis.com/forums/turbo-motor-12/)
-   -   T70 suprer 70 Continued.. Problem A solved Problem B still a problem. (https://www.s-chassis.com/forums/turbo-motor-12/t70-suprer-70-continued-problem-solved-problem-b-still-problem-25428/)
uvamosk Aug 12, 2005 07:31 PM
Ok ok, Found out that The mani i was using was top mount... so I have the turbo thing all fixed up.. Now problem B The Wastegate It wont fit on the manifold cause it hits the turbo... So was thinking.. Ill just make a extention tube with 2 38mm flanges and some Stainless steel tube.. to push it out about 4IN anyone know if that would be ok or will it cause problems with the wastegate doing its job... Also I bought a wastegate that came with 2 38mm flanges ... I dont know if those are spacers for the waste gate or if they are used to make my own mani if anyone could tell me here is a pic of the flanges that came in the wastegate package. Like i stated there are two of them and two gaskets I dont know if im supose to put one on each side of the wastegate as a spacer between it and the manifold or not..
thanks..
http://i3.ebayimg.com/01/i/04/b6/b3/a7_1_b.JPG
