what piggie back system to use?
im looking at getting a piggie back ecu for my 96 sr20 red top i was planning on doing a t78 turbine or if there is a easy to use and fairly cheap (under 1000 dollar) standalone. i was looking at the camp system thru hks but tell me what you think? thanks alot.
If i'm not mistaken, isn't the HKS Camp just a monitoring system? If you buy a standalone for under $1k, it'll probably be hard to comprehend and tune.
As far as a piggyback computer, I'd only recommend the Greddy E-Manage......
Originally posted by phantomsi
ohhhhh thanks for the heads up. what about doing like safc?
The Emanage is a great unit. EXTERMELY USER FRIENDLY!
If you want to get the full tuning effect go for a EMS Stand Alone about $850. It replaces everything...therefore no unnessicary wire crap to take up place. Fuel, Timing and 5 or 6 extra controls for AC, Electric Fans, Shift lamp...Also you can remove you AFM which is great for let more air flow in.
Originally posted by BoogiepopJDM
becareful i was told e-Manage was only for obII so make sure your care is obII i doubt it is OBII are usually the 97-98'
And by the way, OBD-II is 96+..
I always thought that OBD2 was 96+ too but jim wolf says different and I would trust that better than my memory. Go to the webstie and look in tech support and then look in Nissan ECU Idenification Chart
Re: what piggie back system to use?
http://www.microtechusa.com
nissans13
Aug 23, 2006 02:54 PM
drpepper180
13
Dec 18, 2002 05:20 AM
poisonfist
Feb 10, 2002 04:07 PM
