What Timing Should I Be Running?
Old Apr 15, 2006 | 05:49 AM
houmack's Avatar
Hi,
I wanted to know what people are running as the total timing on their turbo cars. Also, what kind of timing are most running under boost?
I'm running a total of 38* of timming but under boost i'm pulling 25* from the 38* to = about 13* of total timing under full boost (14-17psi) and I think I still hear knock. I'm pretty sure I'm running a 8.5:1 compression and running 94Oct. gas. Is this a normal amount of timing to be running with the above conditions? AFR is mid 12's though. Running out of fuel. New injectors should be in next week, but so I know.... What kind of timing map are you guys running?
Cheers.
Old Apr 16, 2006 | 07:01 PM
what kind of motor do you have?
Old Apr 18, 2006 | 09:37 PM
houmack's Avatar
SR20DET
Old Apr 18, 2006 | 09:44 PM
lol i duno what your talking about in your first statement but on the timing belt/ pulley it should read -5, 0, 5, 10, 15, 20 - your timing should be 17ish.... i run 18
Old Apr 19, 2006 | 04:58 PM
zenkislider's Avatar
18 if you have alot of mods, 16-17 if your stockish
mechanicmannic
Aug 20, 2006 08:59 AM
chuxxmixx
Oct 20, 2005 03:51 PM
Jonas
Aug 15, 2003 12:35 PM
strat13
Sep 12, 2002 10:10 PM
