need guidance
i have a few question for you guys if you dont mind did you replace your bushings when you put in your coil overs and or any suspension upgrades. I bought my 240 for 500 bucks and everything on the car is the original equipment since the car was purchased in 1989 I am the second owner and the previous owner was an old lady that never repalced anything beside the brakes and oil. the suspension is so bad the car drops like 2 inches with a full tank if gas. if you did what did you use all i found on the net is energy suspension they have a full replacement kit but I'm not sure how much it cost. Anyways hit me back with some info if you can.
Replace your shocks. Get a shock and spring combo or save up and get coilovers.
Common broken stuff: Tie Rod ball joint Tension Rod bushings Rack and Pinion Power steering lines/pump/anything powersteering This has been discussed a bajillion times. Search button is your friend. |
