Wheel Technical Information
offset recommendations.
Since everybody have conflicting opinions on offset i thought i'd post this that i've found at nissansilvia.com
S15
16 6.5 +45 Stock
16 7 +29 Recommended by Taka Kaira
16 7 +33 Front Recommended by Rays/Nismo
16 7 +35 Recommended by Work
16 8 +38 Recommended by Taka Kaira
16 8 +45 Rear Recommended by Work
17 7 +30 Recommended by Taka Kaira/Rays/Nismo
17 7 +31 Recommended by Work
17 7 +35 Recommended by Work/Rays
17 7.5 +30 Front Recommended by Rays
17 8 +38 Recommended by Taka Kaira/Rays/Nismo
17 8 +44 Rear Recommended by Rays
17 8 +45 Rear Recommended by Work
17 8.5 +40 Rear Recommended by Rays
17 9 +10 SpecS15
18 7.5 +30 Front Recommended by Rays
18 7.5 +31 Recommended by Taka Kaira
18 7.5 +32 Recommended by Work
18 7.5 +35 Recommended by Work
18 8 +36 Recommended by Taka Kaira
18 8.5 +40 Rear Recommended by Rays
18 8.5 +45 Rear Recommended by Work
S14
16 6.5 +40 Stock
16 7 +31 Recommended by Taka Kaira
16 8 +31 Recommended by Taka Kaira
16 8 +35 Recommended by Work
16 8 +38 Rear Recommended by Rays/Nismo
17 8 +25 Front nismoS14: sit even with guards
17 8 +31 Recommended by Taka Kaira
17 8 +36 Front Recommended by Rays/Nismo
17 9 +35 Rear nismoS14: sit a little out
17 9 +38 Recommended by Taka Kaira/Rays/Nismo
S13 / 180SX
16 7 +32 Recommended by Taka Kaira
16 8 +32 Recommended by Taka Kaira/DumHed: stuck out to far
17 7 +35 Recommended by Taka Kaira/InitialSteve/DannyG
17 7 +38 PS13boy
17 8 +22 Front RHiSC
17 8 +30 Front 180athid
17 8 +35 Recommended by Taka Kaira/InitialSteve/DannyG/Midori
17 8.5 +35 Front pitchd
17 9 +30 Rear 180athid
17 9 +40 Rear Mark/Midori
17 9 +38 Rear Recommended by Taka Kaira/Rays/Nismo
17 9 +47 Rear RhiSC
17 9.5 +35 Rear pitchd
18 8 +20 Front 180athid
18 9 +20 Rear 180athid: shreds tyres
original link. click the link for more in depth explanation of offset and clearance issues.
Warning* there is no mention of coilover or other suspension with these offsets so i have no clue if they will clear stock springs, aftermarket springs or coilover kits.
I also did my own research tho and i've heard that the 17 x 9 +38 will clear coilovers (TEIN Flex). I guess you really don't need +5 offset.
pix of s14 with Flex's with the above mentioned rim size and offset
front
back (looks kind of sunken in but not as bad as everybody says they would be.)
another with same dimension wheels
on an s13 with +20 up front and +38 in the back
REMEMBER, these are only recommendations. Offset isn't set in stone. If you find a wheel with an offset that isn't listed above.. do your own math.. trust me it's not that hard.
25.4mm = 1 inch
Additional Info
Tire Rack
Wiki Wheel Info
courtesy of tire rack, wiki, miata.net
S15
16 6.5 +45 Stock
17 9 +10 SpecS15
S14
16 6.5 +40 Stock
S13 / 180SX
17 7 +38 PS13boy
17 9 +47 Rear RhiSC
front
25.4mm = 1 inch
Additional Info
Tire Rack
Wiki Wheel Info
there is no reason not to roll and pull your fenders it is cheap. and you can get way wider wheels and tires... more dish is pimp and staggared wheel sizes on a car that already understeers sucks
What width rims
To Ken Versus Ryu,
In that picture of the S13 with +22 and +35 offsets, what are the widths of the front and rear rims? i really dont want to get flamed for this, but i want to be absolutely sure before i order my rims. Sorry. Im getting ready to order some Fn01r-c and i am looking at the 5zigen website.
Im not going to do the 5lug swap, due to lack of funds and getting married. On the Zigen website the 17X8 +35 are available in the lug pattern i need. How would these look all around? and i also see they havea 17X9 with +20 offsets. would these work for the rear with 17X8 +35 up fromnt? i am really sorry to sound like a newb, but i guess i kinda am one. and get slighty confused. thank you very much, in advance.
Thanks
thanks alot. thats what i was looking for. Because i kept seeing +35 for 17X9 on an S13 but that new offset size (+20 for the S13 on the 5Zigen website) for the FN01R-C's threw me off.
A few more quick questions. Will this require rolling my fenders, if so not a problem. And does anyone have a picture of a S13 with 17X9 +20 wheels?
Thanks again fellas
Thanks again fellas
now i know what to buy! <~ i'm such a noob haha
