FAQ Have a question that has been answered several times on these forums? Enter here!
brake pedal hard
Old 07-15-2007, 05:25 PM
jam1231's Avatar
brake pedal hard
my brakes get hot only after driving about a block or so and the pedal gets hard but the brakes still work but when i take my foot off the gas you can feel the car slowing down without putting on the brakes also the brakes are hot and smell. i change the right rear hose and rebuilt the same caliper.
jam1231 is offline
Old 06-10-2009, 01:13 AM
yetijeff's Avatar
bleed um all, starting with the farthest caliper away moving to the closest caliper to the master cylinder
yetijeff is offline
Old 06-10-2009, 03:44 PM
i disagree, the reason you'd need to bleed the lines is to purge them of air or even old, useless brake fluid. having either of the two in the brake line will would cause the brake pedal to feel soft, or spongy but not hard. a hard brake pedal would most likely be the result of a bad brake booster.
jramosthe1st! is offline
chitodsr
01-05-2008 12:34 PM
95SILVIA14
04-02-2005 02:36 PM
craigkiel
06-01-2004 08:48 PM
s240r
02-03-2004 03:02 PM
Matt_240
11-04-2002 06:22 PM
Quick Reply: brake pedal hard
