speed daddy turbo?!?!?!?!?!
Old 06-06-2010, 07:11 PM
justgotta240's Avatar
ok so i have a 1989 240sx (ka24e) i want to swap it out for a ka24de (i already have) and i figured it would be easier to install when the engine is out of the car or at least get everything ready so im looking for turbo kits
ive come acrossed a few 1 by Greddy 1 by turbonetics 1 by cx racing now i found 2 through google its made by speed daddy (1 has more stuff for $800.00 and the other had less for $600.00) now i want to know has any1 ever used this whats the real difference anything major i want to run about 15 lbs of boost can this do it
in other words is it worth it or can u find a better 1 for a little bit more or maybe less
(questions)
1.will it fit right
2.is it a quality kit (able to run 15 lbs of boost)
3.will i need anything else (besides ecu fuel pump and injectors)
4.can i keep power steering (i dont have ac)
5.how much will it cost to install at a shop
6. is it worth it
justgotta240 is offline
Old 06-06-2010, 09:00 PM
shaban's Avatar
1. doubt it
2. no
3. no
4. yes
5. a lot more than you expect
6. only if you get a quality kit (garret, turbonetics, greddy, etc.)
shaban is offline
Old 06-07-2010, 12:43 AM
well i understand getting quallity kits like u said but for 4,000 bucks i could get a rb26dett for that much
Old 06-07-2010, 12:50 AM
sorry i forgot to post a link to the turbo kit sorry XD
http://cgi.ebay.com/ebaymotors/ws/eB...038427#contact
Old 06-07-2010, 03:46 AM
when an entire turbo kit cost less then a good reliable new turbo then you know something is up do not buy it is a waste of money
battosaii930 is offline
Old 06-07-2010, 08:56 AM
shaban's Avatar
Ok? So what you're telling me is that you would rather get a STOCK rb26 rather than building a KA to be more powerful than said rb26? By the way, the engine isn't that expensive, it's putting it in the car that is expensive. The whole kit is $850, my turbo ALONE was $1050. You do not want to use a no-name turbo unless you want to destroy your motor and waste your money.
shaban is offline
Old 06-07-2010, 09:24 AM
^+1
Biggamehit is offline
Old 06-07-2010, 03:12 PM
im looking for reliable turbo that can run over 15lbs of boost any ideas but im looking for a full kit for like 1000-1500
Old 06-07-2010, 06:27 PM
you say 15 pounds of boost but do you know what that means?
i guess not. different size turbos flow different amounts of air at 15 psi so generally saying 15 psi dosnt mean anything. you need to research b4 you blow $1000 in absolute crap.
if u want a good cheap reliable build you may want too look into Biggamehit's s13 build and go with a Holset turbo but ill tell you right now it isnt gona cost $1000 to finish everything
Old 06-07-2010, 07:41 PM
yeaup.. my turbo was cheap but reliable.. but everything else around it cost.
I spent roughly 2500 dollars on tunning equipment
Old 06-07-2010, 08:47 PM
well the thing is ive heard of the cx racing turbo kit (230whp @ 8lbs of boost stock ecu injectors and fuel pump) well if i start with that as in use everything and slowly upgrade from there like the actual turbo then the bov then wastegate (probly wastegate first ive heard of the cx racing wastegate going bad or messing up) but does that sound like a good idea or should i go all out and spend $4000 ar once to get a greddy kit
or should i buy a intercooler kit and start from there
http://www.cxracing.com/mm5/merchant...ry_Code=TRB240
Old 06-07-2010, 11:44 PM
personal opinion... put your own kit together and learn.
if you are going to buy a kit... its worth your time to buy a quality one.
I started with a ssac kit and oe nissan turbo parts. within about 5 months my setup changed about 3 times untill I got settled with the holset.
Old 06-08-2010, 01:27 PM
ok well can u recomend a turbo biggamehit thats not too exspensive
Old 06-08-2010, 05:32 PM
Ill start by saying, if you have the money spend it right. Also visit KA-T.org many many people part out entire setups.
If your expereince level is not high and you dont have the means to perform fabrication yourself.. the best method of boost would be to use a T28 or T25 becuase you can use ALLL the Sr parts when coupled with the T25/28 KA manifold. It would require no welding at all if you get a oil drain tap that has the rubber insert and screws.
please review the KA-T Build sticky at the top of the page in the KA-T forum
Old 06-10-2010, 02:28 AM
wait is it the t25/t28 or the t25 or t28 sorry for all the dumb questions i would rather be tagged as an idiot for asking 1000 questions than be the idiot the blew up a 240 and if i went with a t25 or whatever i would have to rebuild the engine right like forged pistons and rods
Quick Reply: speed daddy turbo?!?!?!?!?!
