89 240sx engine bay screaming noise?
I have already checked the timing chain. Its fine, now do you guys think it is the powersteering pump? The sound starts up when my car is running cold. (1g-3.5g rpm it makes the sound)
hopefully some poor s13 owner knows where im coming from....
thanks
thanks
Try turning the wheel all the way in either direction then apply a little more pressure, if you hear a screech then your looking at a power steering pump problem. Also try spraying some belt dressing to the p/s belt, the screech could just be the belt slipping.
dp
dp
It myte be Your belts...To check open hood, start car (cold) if You have noise pour little water on the belts, if noise stopped, it is Your belts.Tighten them,or replace,as needed.Note: Don't overtighten ! Belt should move approx 1" when You push it with Your finger.
Yeah, I've got a 90 that makes that noise when it's cold. Usually once I get the car going and it heats up the sound goes away. I've figure it's the belt slipping. It's been doing that each winter for years and nothing bad has happened so it can't be that serious.
Best of luck,
Matt
Best of luck,
Matt
I had a similar scream and I think it was the belt wheel on my A/C compressor - shot it with some WD and its better now - but again, I am not 100% sure it was this and since it only happened recently it may have been something else as well and it fixed itself
Good Luck
JF '89 240sx 140K Mi.
Good Luck
S13freak
05-14-2004 01:41 PM
Space Boy Matt
West Coast/Hawaii
03-23-2004 08:03 PM
