93 coupe door speakers
Old Oct 30, 2004 | 05:42 PM
240-4-me's Avatar
I'm going to be replacing the speakers in the doors of my 93 coupe next week. I will be swapping out the originals with upgraded 4x6's. Question is how do the speaker covers come off, or do I need to pull the entire door panel off to change out the speakers???
As always, thanks for your help.
KFG
Old Oct 31, 2004 | 10:25 AM
fouz's Avatar
i wanna know the same thing but on the 95 se.i tryed pulling out the mesh grill and pulling out the little ring that holds the grill but it didnt just pop off.i dont wanna tear it up.i think i need 5 1/4 speakers but i wanna double check before buying.help which "pops off" the ring or the mesh grill?
Old Nov 1, 2004 | 08:55 PM
only240ntwn's Avatar
On my 1992 240 I had to remove the door panel to put my in. (I do beleive that you can remove the screen/mess after you take the panel off) to remove the panel take off the door handle (inside) there is one srew on this and then you turn it 90deg or 180 deg and it should come off remove the screw in the din buy using a flat head to remove the plastic peice that covers it and then the screw. I also beleice that there is a screw in the door latch (used to open the door) remove that. and then you remove the window roller, asumeing its a manual, you have to remove the retainer clamp behind the plastic gaurd...dont loose it when I removed mine with a flat head screw driver i didn't even see were it went...but I heard it leave. then pop the door panel off. I havent done this in a long time so dont quote me on all this but its how I remember it
Old Nov 2, 2004 | 02:47 PM
fouz's Avatar
same for the 95 se.door panels must be removed.the grills dont "pop off".the rear deck has to be removed also.the speaker grills for both door and rear deck can only be removed after the door panels/reck deck has be removed.just thought i would post this here.and BTW the 95 se takes 6 1/2 speaker in the door and rear(this is the clarion 6 speaker system). im just wondering,is that a factor amp that is mounted under the rear deck?
Old Nov 8, 2004 | 06:30 PM
240-4-me's Avatar
Thanks to "only240ntwn" for the help with the door panel removal. They came off easy. I did have to cut and modify the plastic speaker housing but all ended up well. The new AIWA CD player and 4 new speakers certainly make the ride to and from work more enjoyable.
Yanman233
Sep 7, 2006 05:29 AM
Gonad
Apr 12, 2005 07:00 PM
twelvea
Apr 11, 2005 06:12 PM
soulja40
Dec 29, 2004 07:06 PM
l2aine
Jun 3, 2004 07:38 AM
