Audio system
Old Sep 29, 2005 | 07:18 PM
bullet23's Avatar
Audio system
I have about saved up enough money to do much of my cosmetic mods and Audio Visual Mods. I was wanting to run my Audio/ Visual ideas by you guys to see what you thought. So here is the List:
- Pioneer AVIC-N1
- Pioneer 6.5 Speakers front and rear
- Pioneer GM-6100f amp
- Pioneer GM-5100Y amp
- 2 Pioneer TS-W256C/DVC
The subs and Amps are going in the trunk I want to build custom boxes for the subs and mounts for the amps
So how do you all think that would sound?
Old Sep 30, 2005 | 02:23 AM
not bad if you get the enclosure right.
Old Sep 30, 2005 | 05:15 AM
shotty53's Avatar
make sure u build the sub boxes to factory specifications or they wont have full potential and can possibly sound like shiet
Old Sep 30, 2005 | 09:54 AM
bullet23's Avatar
Where can i get the factory specs for the boxes?
Old Sep 30, 2005 | 03:11 PM
The subs should have specs with them as far as enclosure interior volume... now to get that suggested volume in a custom box is all on you + measuring tape + calculator.
Old Sep 30, 2005 | 03:55 PM
shotty53's Avatar
if the subs dont have them, then the site of the manufacturer should
Old Sep 30, 2005 | 04:27 PM
nsn240's Avatar
you guys build them out of 1/2 MDF right? I got a box and subs for free... but the thing wieghs so much the entire back of the car sank...
Old Sep 30, 2005 | 05:35 PM
wikd240's Avatar
never build a box out of 1/2 in mdf... use at least 3/4 inch... half inch will flex way too much and you will loose performance out of the woofers... and any pioneer dealer will have specs if you cant find them on the net...
when you build the box to the corect volume make sure it is internal volume after speaker displacement is figured out of the equations...
here is the specs for the box... internal volume sealed...22.64 litres or 0.799 cu/ft per woofer... i would suggest you build the box 0.85 cubic foot per woofer sealed and put in half a bag of poly fill for each woofer...
the reason for using poly fill (synthetic pillow filling) it makes the woofer believe it is in a bigger box than it actually is... producing higher levels of spl... plus it will deaden any resonance inside of the box and reduce any unwanted noise from the enclosure itself...
good luck in your building... and one more thing remember that the enclosure size is inside length x width x hight devided by 1728... that will give you internal cubic foot volume of the enclosure...
dokta
Feb 20, 2007 04:17 PM
nissans13
Aug 23, 2006 02:54 PM
94cc0rd
Feb 21, 2006 11:47 PM
leiferik1
Jul 25, 2002 07:42 PM
DeRaNgEd
Feb 24, 2002 01:31 PM
