radio speakers inop
Old Sep 30, 2005 | 11:27 AM
avengerx43's Avatar
radio speakers inop
the front and rear speakers in my 1993 240sx stopped working, i had hooked up an amp about two weeks ago and the speakers and subs were working great, yesterday i was driving and all of of sudden they shut off, i checked all the connections on the radio and there all good, the amp and subs are still working but no interior speakers, any ideas anyone, please!!!!
Old Sep 30, 2005 | 11:49 AM
Cape 240's Avatar
the connections on your deck may have come loose. pull it out and check. The wires may have also shorted out, check all connections.
I hope you diddn't wire the amp to your speakers, the stock speakers aren't capable of much wattage.
Check your fuses.
Old Sep 30, 2005 | 03:10 PM
^ agreed - where exactly did you hook up the amp in the first place?
Old Oct 4, 2005 | 03:37 PM
wikd240's Avatar
another thing to look for is a shorted - blown speaker... it can cause the speakers running off of the deck to shut down (that is if you did not wire the amp up to the interior speakers)
Old Oct 4, 2005 | 06:48 PM
Cape 240's Avatar
I recently had a problem because i installed a 200w head unit, pushing 50 watt to each speaker.
I replaced the front speakers with 120w (capable) 3-way pioneers
BUT, i left the rears stock (had to order 2 more for rear) The headunit was pushing too much wattage to the rears, they were gagging and sending it back to the fronts, the fronts were then making wierd popping noises, all because the power was too great.
Make sure your not pushing too much power to un-capable speakers.
I've since-then installed all 4 pioneers, sounds GREAT, no popping anymore.
Krise013
Jun 27, 2003 05:20 PM
DiZZy
Nov 10, 2002 02:21 PM
leiferik1
Oct 31, 2002 11:13 PM
leiferik1
Sep 27, 2002 03:01 PM
