third set of speakers
Old May 22, 2006 | 09:47 AM
iceman4's Avatar
so i have an extra set of 6.5 rockfords sitting in my basement and i was wondering how, if even possible, to wire them up to a deck. they would be the 5th and 6th speaker in my car...or do i need to buy an amp for them? i have a panasonic aftermarket deck that is 4 x 50....so i guess it would suck if i just piggybacked them onto the back channels right?
Old May 23, 2006 | 03:56 AM
Joel 180's Avatar
yeah you are going to need an amp to run those
maybe buy a bridgable or low impedance stable amp and run two pairs in parallel
Old May 23, 2006 | 09:30 PM
Dounveeme's Avatar
technicly yes you could run them off of the same channels as the other speakers is it reccomened? no. have i done it? yes on multiple cases, and it will work just fine and shouldnt hurt anything. it will usually divide the power in half. really no worries most likely it will saticfy you for awhile. you'll want more,More,MORE! and you'll amp them.
Old Jun 7, 2006 | 11:46 PM
iceman4's Avatar
so will it even help to put them in then if it cuts the power in half? i plan on buyin an amp, just would rather spend it on things that make the car go faster first, then ill get the amp.
Old Jun 8, 2006 | 01:28 AM
Dounveeme's Avatar
you should notice more depth to the sound.
if you have one of the newer style panasonic with the day/night face plate like the one i have which it sounds like you do. the 50x4 was enough to run my Infiniti Kappa Perfect 6.5 components just fine without a seperat amp and i was told it wouldnt be enough power to run them since they are rated at 90wrms and that i would need an amp. im sure i will be enough to run one more set for a bit.
Old Jun 8, 2006 | 01:45 AM
iceman4's Avatar
k cool ill try it tomorrow!
battosaii930
Jun 29, 2008 08:58 AM
shaveds13
Nov 22, 2006 08:11 PM
nisilvia
Nov 18, 2004 05:06 PM
Krazyballa3
Jun 9, 2004 04:13 PM
SilvaPwr
Oct 10, 2002 04:33 PM
