What is this for?
What is this for?
Well i have some amps for my car that are waiting for me to install. While i was looking at the inputs (rca) i noticed that next to the inputs are a set of outputs, also RCA. I was wondering what those outputs are for. Ill try to post a pic tomorrow. I was thinking that since it has a bandpass filter that maybe the output is for the frequencies it filters out. Idk.
both answere are right... in some cases you use the outputs to bridge 2 amps together like the crossfire bmf1000 or the memphis 1000d amps... on older orion amps it was used to control all other amps downstream from the first... change settings on the first amp it changed the rest of the amps...
in other cases it is a straight unmodified signal passed through the amp allowing you to connect that signal to another amp...
Originally posted by LA_phantom_240
so maybe i can connect the output from my alpine to another identical one im looking at buying, and run all 4 speakers plus 2 subs?
I dont really understand the bridge thing though
usually though, bridge is when you run a 2 channel amp as a 1 channel or something to that effect. Bridging amps is very technical shiot.
