Wiring-up an amp
Old Feb 27, 2007 | 02:53 PM
AZdrifterS13's Avatar
Wiring-up an amp
Can anyone give me ideas on how to get the 12V cable from the battery, through th firewall, and to the amp? I dont know where I will be able to run through the firewall. Anybody else know how?
Old Feb 27, 2007 | 04:40 PM
nixad's Avatar
Just use the fat wire behind the fuse box in the driver side kick panel.
Old Feb 27, 2007 | 05:01 PM
LA_phantom_240's Avatar
I ran mine through the grommet for the ECU. I cut it with a razor, and pushed it through. Im running 2awg as well, and isnt exactly small. Tucking the wire under the carpet is easy. Just take off the trim where the carpet meets the door jamb (forgot its name) and it fits nicely under there. Running wires in my 240 was teh easy.
Old Feb 27, 2007 | 07:05 PM
through here,
you'll need a screw driver
sorry i just had to keep that joke going.
but seriously if you plan on running that wire to an amp make sure that the rca jacks are not ran through the same path. if you don't you'll get interference, static most likely.
Old Feb 27, 2007 | 07:26 PM
thats a great picture there, too bad i have no idea where that is! haha. when i wired my old car, it took me seriously like and hour and a half to figure out how to run the power wire through, and finally i just gave up and put it through a whole somebody mad in the wheel well. it was so ghetto.
Old Feb 27, 2007 | 07:33 PM
my bad, i took a close up beacuse it's dark out. but is is the grommet that LA phantom was talking about. once you have the wire inside just run it under the carpet.
Old Feb 28, 2007 | 12:07 AM
ahhhhhh... i finally got it all wired up. it only took me a couple hours, and it would have been less but i had to mess around with one of my subs and remount my amp to the back instead of on top. but yeah, they hit sooo hard, way harder than when they were in my acura. Oh and i did put it through the grommet for the ECU wires. Thanks alot for the help guys.
boosted-alty
Feb 15, 2007 12:08 PM
wannaS15
Apr 12, 2006 05:18 PM
KingOfDrift
Dec 1, 2005 01:25 PM
iceperformance
Oct 8, 2002 07:23 AM
SilvaPwr
Sep 23, 2002 04:29 PM
