92 240sx limited slip diff
Old Jan 22, 2004 | 06:56 AM
bonomo's Avatar
I was wondering if a 92 240sx fastback has limited slip , if it does it really doesnt work good around turns. and do the 300z diff fit on the 240s with no mods..
Old Jan 22, 2004 | 10:37 AM
First off moved to the drivetrain section, please post in the right area.
The only S13 240s that had a vlsd were Super HICAS equipped hatchbacks. So if its a HICAS model then it should have a VLSD. If not then 95% sure it doesnt, unless they modified it to have one. Z32 diff do fit, but there is some modding needed. find a 90+ Z32 non turbo VLSD, you need to swap output flanges.
Old Jan 22, 2004 | 01:02 PM
VT_motor's Avatar
HyJynX...question? They guy i bought my 92 from told me that it has a LSD but it is not a hicas. He said that the original diff blew and the nissan dealler put one in. If that is true do you have any idea what kind it would be. I would take it apart but the weather here sucks and i don't have the time to check. thanks
Old Jan 22, 2004 | 02:28 PM
RS13's Avatar
do a burnout and see if you lay one or two black stripes
one is an open diff
two is a LSD
Old Jan 22, 2004 | 03:08 PM
bonomo's Avatar
is there any other nissan other vlsd that woul fit because the 300z hard to find
Old Jan 22, 2004 | 04:08 PM
VT: The dealership could have possibly installed a VLSD in...Try doing this test. Lift the rear end of your car, make sure the car isnt in gear, spin one wheel. If the other wheel spins with it then you should have a LSD, then try it IN gear. The other spin should spin the other way(or is it with it?)But if it doesnt spin at all then you dont have LSD. I hope i explained that well...
bonomo: Here is a site, look at the bottom http://**********/links/installs/lsd2/index.htm
Old Jan 23, 2004 | 05:20 AM
VT_motor's Avatar
thanks a lot..
Old Jan 23, 2004 | 10:44 AM
no prob
Old Jan 23, 2004 | 04:49 PM
bonomo's Avatar
thanks....
Old Jan 24, 2004 | 10:39 AM
elks240's Avatar
infiniti j-30 vlsd bolts up with output shafts and rear cover off original open diff---also you can look at the fill point on the diff and if it is lsd then it will say it
Old Jan 26, 2004 | 11:39 AM
ProricanRacer's Avatar
Okay...I did that test yesterday..I lifted my car up in the rear and put it in gear...they both spinned but one seemed to spin faster than the other...does this mean I have LSD or is it just open diff?
Old Jan 26, 2004 | 12:44 PM
Did it spin the same way or opposite? Did you try it in neutral as well? In neutral both should move the same way freely.
Old Jan 26, 2004 | 12:46 PM
bonomo's Avatar
what year is the j-30
Old Jan 26, 2004 | 12:49 PM
j-30 is from 93-97. Check the link i posted earlier for the modifications needed for each year
Old Jan 26, 2004 | 01:13 PM
bonomo's Avatar
are they easy to find?
