Bleeding The Clutch?
Old Sep 16, 2004 | 07:21 AM
cticknor666's Avatar
I searched around but couldnt really find a def answer to what i was looking for. Could someone do a write up on how to bleed the clutch on a 89 240. For some reason the clutch is stuck to the floor and wont come up and i saw on another post that after he bleed the clutch it was fine again. I jus dont know how to go about doin it. Any help would be great. Thanks
Old Sep 16, 2004 | 09:06 AM
http://files.automotiveforums.com/up...967560pic2.jpg
http://files.automotiveforums.com/up...181092pic1.jpg
That should help you out
Old Sep 16, 2004 | 10:11 AM
My_Shaldan's Avatar
link doesnt work. pls help, im having the same problem. thanks.
Old Sep 16, 2004 | 03:42 PM
Hmph, I will fix it when I get home.
Old Sep 18, 2004 | 08:06 AM
Links still broke
Old Sep 18, 2004 | 09:06 AM
How bout now, copy and paste
Old Sep 18, 2004 | 07:11 PM
Thanks a ton -HyJynX-. Do you know how hard it is to get to that bleeder screw??
Old Sep 18, 2004 | 10:23 PM
Also, it says to pump the clutch pedal, how can i do that when the pedal is stuck to the floor?
Old Sep 18, 2004 | 11:22 PM
Raise the car up and it should be a snap. IIRC its on the passenger side of the trans.
Once you close the screw the pressure would go back to the pedal, so you can pump it. Hope it works out right
Old Sep 29, 2004 | 02:29 PM
Ok, i bleed it and got it working again. That was about 2 days ago. Drove it all day yesterday, go to leave today and the pedal is back on the floor with no pressure ont he clutch. Pop the hood and look in the resuvoir and its empty. Now im startin gto think either A. I didnt tighten the bleeder screw enough. which im pretty sure i did. or B. i have a leak somewhere. Now my question is where would i look for the leak? I never see anything spots in teh driveway or anything. Whats goin on anyone know?
Old Sep 29, 2004 | 02:55 PM
Could be a leak from where the pedal attaches to the master cylinder. Follow your pressure line and se if there is a leak as well
Old Sep 29, 2004 | 03:08 PM
How hard is it to get back to look where the master cyl and the pedal meet??
Old Sep 30, 2004 | 10:26 AM
Get a flashlight and take a peak down there. Just follow the pedal up and up
Old Oct 1, 2004 | 02:05 PM
Ok, i've looked and it looks like its coming from around the bleeder screw area, which i belive is the slave cylinder. How much are those to replace? And how hard?
Old Oct 2, 2004 | 01:55 PM
You can go to autozone and get it for 14 bucks or so(I think), that is for the whole slave cylinder. Or you can go to the junkyard to find one...
