which car
what other nissan/datsun has a LSD that would be a direct bolt on to an 89 S13?
are u talkink complete pumkin or just internals?
housing and internals. I don't really feel like taking the rear differential apart
the non turbo 300 will work with diffrent output flanges.
other LSD equipped S13's S14 will work i think 95+ J30 r32 gts-t skyline any others? |
Originally posted by altima/240sx housing and internals. I don't really feel like taking the rear differential apart |
hey, speaking of internals swpaing
wouldn't the casing have to be swapped if you were gona install the LSD into a non-LSD casing. i thought the pumkin was larger on LSD units:dunno: |
I think the have slightly different housings, but with the same internals. That brings up a good point I forgot about:rolleyes: you have to swap the driveshaft with a stock lsd, right?
i think its the axles(is that what u ment?)
I thought the driveshaft was shorter in the abs/lsd equiped cars?
i think olny on the automatics
