which car
Old Nov 17, 2002 | 04:42 PM
altima/240sx's Avatar
which car
what other nissan/datsun has a LSD that would be a direct bolt on to an 89 S13?
Old Nov 17, 2002 | 05:52 PM
rudeboy's Avatar
are u talkink complete pumkin or just internals?
Old Nov 17, 2002 | 05:54 PM
housing and internals. I don't really feel like taking the rear differential apart
Old Nov 17, 2002 | 06:00 PM
rudeboy's Avatar
the non turbo 300 will work with diffrent output flanges.
other LSD equipped S13's
S14 will work
i think 95+ J30
r32 gts-t skyline
any others?
Old Nov 17, 2002 | 08:33 PM
I'm with Stupid's Avatar
Then you're limited to usdm S13 lsd's only. Do the internal swap it'll be easier than finding a S13 lsd, if not maybe cheaper
Old Nov 17, 2002 | 09:25 PM
rudeboy's Avatar
hey, speaking of internals swpaing
wouldn't the casing have to be swapped if you were gona install the LSD into a non-LSD casing.
i thought the pumkin was larger on LSD units
Old Nov 17, 2002 | 09:27 PM
I think the have slightly different housings, but with the same internals. That brings up a good point I forgot about you have to swap the driveshaft with a stock lsd, right?
Old Nov 17, 2002 | 09:40 PM
rudeboy's Avatar
i think its the axles(is that what u ment?)
Old Nov 17, 2002 | 09:48 PM
I thought the driveshaft was shorter in the abs/lsd equiped cars?
Old Nov 17, 2002 | 09:50 PM
rudeboy's Avatar
i think olny on the automatics
2forties
Aug 16, 2006 11:21 PM
S13DET
Aug 30, 2005 04:52 PM
1995 240sx
Jul 30, 2005 01:40 PM
d4vech3n
Jan 5, 2005 08:19 PM
polishmafia4u
Nov 8, 2003 05:55 AM
