Changing clutch*new pics*
ok me and my cousin are trying to change the clutch on his 240, its turned out to be more work than we expected but, i think we have all the tranny bolts removed and we removed the slave cylinder and starter, once all the tranny bolts are off how does the tranny come off? do we pull it or what, what method do you guys use? also is it absolutely necessary to remove the driveshaft?
LOOK DOWN FOR PICS |
here is a walk though
http://www.**********/links/installs/flywheel/ also when you put you tranny back on the top 4 bolts are tourqed to 36lbs and the bottom to 29 |
thanks a lot
recommended to diy? considering limited tools? or take it to a shop and get raped by shop rates? just considering doing it myself...
it is ez to do your self provided you can raise the car pretty high.
Matt just remove the bolts then disconnect the drive shaft. Wiggle the tranny off. Getting it back on is the PITA. just reverse the way you took it off. SW20- I buy th parts yourself and work a deal out with a shop to let you use the lift and tools. |
yes its not hard ou just need a 1/2 drive and a $25 set of craftsman sockts ada tourqe wrench
plus jack/jackstand |
yes we have the high raising 3 ton jack and a small jack holding the tranny for support and 2 jack stands holding the car up also, but if you got all the tools necessary and you got time then id say you can diy, but its just more than what i expected to do. And btw thank you all for helping me out, i thought i would get flamed for having a integra on here but u guys are cool thanks a lot
hey we are all car enthuasists(sp?) This board is great because when someone asks a resonable question they will get great answers, now when someone asks a stoopid question well commence wit the flaming. haha
meh i have two tegs an my project s13
but iowned my s13 first |
damn... i sure wish i dropped $60 for a tranny jack and done it myself...
paid $400 for a shop to do it instead.. :*( oh well, on the SR/DOHC KA will DIMyself.. lol. |
6 Attachment(s)
here are some pics of us doing it,
old clutch Attachment 29528 Attachment 29529 new clutch on Attachment 29530 but we ran into a problem this piece broke off the tranny Attachment 29531 Attachment 29532 http://img.photobucket.com/albums/v8...x/IM003919.jpg can that be fixed or what should we do? it just broke off when my cousin(owner of the 240) was doing something with it pic of car in the garage Attachment 29533 |
thanks for sharing mang...gonna pay a shop to do it monday :confused: . needed a new clutch asap, maybe do it myself some other time...good info in this thread though :thumb:
dam that looks pretty bad, i would jus drop by a junk yard or any place that does swap, they should have a tranny laying around somewhere, i dont think it should cost much
Originally posted by sr20det power dam that looks pretty bad, i would jus drop by a junk yard or any place that does swap, they should have a tranny laying around somewhere, i dont think it should cost much |
