Even worse clutch problem
Old Dec 18, 2005 | 02:22 AM
Azhenk's Avatar
I posted a clutch problem not too long ago. Looks like I have an even bigger problem... It seems that the reason why my clutch was not activating was because of a release bearing problem. Well anyways I have a brand new 4 puck clutch from ACT that is stuck in my transmission shaft. I fitted the clutch in and aligned it, went in smoothly too. Taking out the transmission was super hard because the clutch was in there the way it was. ACT would replace my clutch if I send it back in "in one peice". I was thinking of taking it out with a 4 prong puller. May be the best way to remove the jammed clutch without damaging it or the tranny. If anyone out ther knows a better way to take out the clutch please let me know. In addition to that that mother ****er is really jammed in. So back that even a crowbar was not even able to remove it.
thx for reading and hope to hear some good advice,
-AZK
Old Dec 18, 2005 | 04:39 PM
Levi SPL S14's Avatar
are the teeth on the shaft messed up at all?
Old Dec 18, 2005 | 04:47 PM
Azhenk's Avatar
I cannot really tell because the clutch is so jammed in, as if it didn't even line up with the teeth when the tranny was put in. I talked with the friends that put in the tranny while I was away, said it had some troubles stabbing it--could explain why it's jammed. Hopfully its still OK...
Old Dec 18, 2005 | 07:28 PM
Ron Smith's Avatar
How could that have even happened? If it is stuck to the main shaft, which is splined, then something is really screwed up. If the splines are damaged then you will need to replace tranny or shaft. I'm not sure you can even fine a 4-prong puller that is big enough to fit around the circumference of the clutch itself. That would be a logical way, if not the only way. Don't pry, hammer, etc. You want to evenly pull it towards the rear without further damaging the shaft, if it hasn't already been damaged.
Old Dec 18, 2005 | 11:39 PM
^ ya damn can you post a pic?
Old Dec 19, 2005 | 11:35 AM
Azhenk's Avatar
Going down to the shop today, I'll take a few pics.
Old Dec 22, 2005 | 03:34 PM
Azhenk's Avatar
Thanks guys for all your help, but unfortunatly the puller didn't get my clutch out--it bent it instead. So I have no choice but to cut it and hope that the splines on my tranny shaft is still in good shape. Oh and if anyone is sponsored with ACT and could get a nice disc on clutch discs that would be great as well.
thanks again,
-AZK
Old Dec 28, 2005 | 01:27 AM
Azhenk's Avatar
Just in case you guys were wondering what happened to my clutch problem I had no choice but to cut the clutch. I cut off the 4 pads so I could get a good hook/leverage point for my puller. And yes, the puller did do the job since it's capacity was 5 tons. The splines on the tranny shaft is still in perfect condition. I went out and bought a 6 puck race disc and is now assembled. I will put the tranny in tomorrow. Wish me luck guys, hope for a smooth install . I'll get those pics up ASAP for you guys to take a look and to shed a tear for my destroyed clutch disc, I know my eyes began to water every time a peice of my disc ripped off.
-AZK
Old Dec 28, 2005 | 02:13 AM
good luck with the new one
irax
May 25, 2004 10:49 AM
SLIDE OR DIE
Jan 29, 2004 12:17 AM
Bryan
Jan 19, 2004 03:43 AM
Emopunk96
Aug 8, 2003 07:29 AM
kackarot
Feb 25, 2002 12:57 PM
