im stumped guys
Old Dec 1, 2003 | 12:49 PM
kramsuey2268's Avatar
Unhappy im stumped guys
Last night I bled my hydraulic clutch lines and in doing so, I have lost all clutch pressure. Any of u guys who have bled your system before Id appreciate some suggestions. (if I have any air bubbles in the lines will I have no pressure or some pressure?)
Old Dec 2, 2003 | 05:04 AM
StanBo's Avatar
Did you bleed the damper then the line to the tranny?
I think another guy had a problem with this and I just showed him a picture of where to bleed the system.
Anyway I screwed around for an hour before removing the plumbing to the damper box and lines associated with it.
Clutch bled fine and works great.
Now it is just a bit sensative but it is more direct.
Old Dec 21, 2003 | 04:56 PM
Drift-Obsession's Avatar
anyone find those? i have the same problem.
how abouts would i go bleeding the damper?
Old Dec 31, 2003 | 01:24 PM
draggin's Avatar
sounds like a bad slave cylinder. check that out.......
Old Jan 1, 2004 | 02:05 PM
Sizzzoooo's Avatar
i'd prolly change the clutch master cylinder and change he slave cylinder while you're at it.
very cheap parts
Coastie240guy
May 9, 2013 02:51 PM
240 Freak
Oct 12, 2004 05:15 PM
JMAN
Jun 11, 2004 09:04 PM
kackarot
Sep 25, 2002 01:58 PM
vtec killer
Feb 11, 2002 06:53 PM
