Ka24E engine fit in de tranny?
Old Feb 1, 2005 | 09:40 PM
juls213's Avatar
Guys will a k24e engine fit in a k24 de tranny and if so do you have to do anything special in order to make it fit?
Old Feb 2, 2005 | 08:32 AM
Levi SPL S14's Avatar
No you have to change the bell housings
Old Feb 2, 2005 | 08:36 AM
drnovascotia's Avatar
i think you worded that backwards. . . do you mean will a DOHC tranny mount on a SOHC engine ? if so then yes. . all trannys are interchangeable
Dr.
Old Feb 2, 2005 | 01:16 PM
juls213's Avatar
No, I have a k24e automatic and want to see if it will fit in a k24detranny, because the k24de motor is blown
Old Feb 2, 2005 | 03:41 PM
GAH AUTOMATIC NO!!!!!!
Old Feb 4, 2005 | 11:28 AM
juls213's Avatar
Someone please answer my question I have a ka24e engine with an auto tranny, I am wondering if you can fit the ka24e engine into a ka24de manual tranny. If no why not?
Old Feb 24, 2005 | 06:08 AM
iroc07's Avatar
it should bolt up fine. but you need a flywheel, clutch, crossmember, clutch master cylinder, slave cylinder, clutch line, clutch pedal assembly, and modify or buy brake pedal assembly, and make the holes in the firewall so you can mount the pedal and master. then you can start cutting the floor of the car so you can stick the shifter through it. sound like fun yet?
Old Feb 24, 2005 | 05:13 PM
cooch's Avatar
well i just finished putting a ka24e into my 93(ka24de) car using the dohc tranny onto the sohc motor and it bolted up just the same with no mods...auto tranny may be different but thats probally about it.......as long as the engine is already out and all just unbolt it and see how close it will be...whats the worst that can happen
Old Feb 24, 2005 | 08:37 PM
djradam's Avatar
sounds like the car had auto, but wanting to know if a manual can go on the same engine. if that's the case, then read iroc's post.
i'm am highly confused on what is going on here ... plus, you can't put an engine into a transmission. i'm sure you know that, so you must've mispoken many times. you SHOULD say (for future reference), will xxxxx tranny bolt on to xxxxxx engine. much much easier to understand
Old Feb 26, 2005 | 05:37 PM
juls213's Avatar
Thanx, sorry about that well it sounds like to much trouble and time so I don't think I will do it, thanx for input
Old Feb 28, 2005 | 01:46 AM
Nismo1182's Avatar
the engine will bolt on to the 5spd tranny, you just need to put the 5 spd flywheel and bolts on it along with converting the rest of the car.
and whoever said you need to cut the floor to fit the shifter, you dont. the hole is already there and its the same size regardless if the car is auto or not.
Xren17
Jan 19, 2006 08:55 PM
juls213
Feb 5, 2005 08:20 PM
spindrift187
Feb 20, 2004 02:34 PM
Nissmo180sx
Dec 23, 2003 08:58 PM
SRdave240
Apr 24, 2003 07:44 PM
