manual ka24e speed sensor
can someone tell me where on the sohc manual transmission i could find the speed sensor? ...i want to know which sensor is the correct one before i start yanking all of em off
wats the easiest way to access the speed sensor? (i.e. underneath the car, from the shifter, etc) how is the speed sensor attached to the tranmission? (i.e. via screws, bolts, just yank it off, etc) finally, will removing the speed sensor require refilling transmission fluid? |
I Don't Know
from underneath is where you want to get it, it has two machine screws holding it onto the transmission and yes some fluid will be drained.
speed sensor has one 10mm bolt. and once you unplug it your fluid will run all over your face.
i rememberer 2 but i replaced mine years ago so there probably is only one |
