manual ka24e speed sensor
Old Aug 28, 2006 | 11:58 PM
aurora61's Avatar
can someone tell me where on the sohc manual transmission i could find the speed sensor? ...i want to know which sensor is the correct one before i start yanking all of em off
wats the easiest way to access the speed sensor? (i.e. underneath the car, from the shifter, etc)
how is the speed sensor attached to the tranmission? (i.e. via screws, bolts, just yank it off, etc)
finally, will removing the speed sensor require refilling transmission fluid?
Old Apr 26, 2007 | 05:38 PM
FuriousZ's Avatar
I Don't Know
Old Apr 26, 2007 | 06:30 PM
from underneath is where you want to get it, it has two machine screws holding it onto the transmission and yes some fluid will be drained.
Old Apr 26, 2007 | 08:20 PM
speed sensor has one 10mm bolt. and once you unplug it your fluid will run all over your face.
Old Apr 26, 2007 | 09:27 PM
i rememberer 2 but i replaced mine years ago so there probably is only one
tallic_red240sx
Sep 4, 2006 10:33 AM
pzofsak
Aug 29, 2005 09:15 PM
2fast4y0u
May 21, 2005 10:24 AM
2fast4y0u
Apr 1, 2005 10:22 PM
spoolin240
Jun 8, 2004 11:29 AM
