Possible Fuel flow problem
I have a problem with my car starting after sitting for about 8 hours. I think it could be a tiny hole in the fuel line that is releasing fuel throughout the day. It must be a tiny hole because there is never any fuel on the ground. Has anyone else had this problem? If you have had this or a similar problem I would be happy to hear your suggestions on how to fix it.
I don't see how it could be leaking fuel if there is never any underneath the car...
Check the fuel filter, fuel pump, and fuel pressure regulator. |
What led you to the conclusion that it's a fuel leak? Have you checked the usual suspects when dealing with starting problems? i.e. starter, starter relay, fuel pump, etc.?
