rear end sounds?
Old Sep 27, 2004 | 06:59 PM
240sx 5spd's Avatar
rear end sounds?
92 Nissan 240sx se 5 spd. been hearing a lound cunk sound in the rear-end i have no clue where it's coming from.
When I go to shift into a gear driving normal. i'll let the clutch out. and i'll hear this sound from the rear-end and sometiems I can even feel it on the shifter... Would this be a driveshaft problem?
Old Sep 28, 2004 | 04:07 PM
240sx 5spd's Avatar
any help???
Old Sep 28, 2004 | 05:08 PM
Texas240's Avatar
Diff
Old Sep 29, 2004 | 12:13 AM
240sx 5spd's Avatar
ummm Diff? what is Diff???
Old Sep 29, 2004 | 09:36 AM
Differntial is a possibility, might be driveshaft...but more then likely your differential is out. How many miles is on it
Old Sep 29, 2004 | 10:09 AM
240sx 5spd's Avatar
miles on the car 180k. miles on engine 60k. i understand a driveshaft i removed one before. but what is a differential? are those the gears inside that box-looking thing?
Old Sep 29, 2004 | 10:19 AM
http://www.4x4abc.com/4WD101/img/diff.jpg
it's not from a 240, but here's a pic to give you an idea of what a diff is... it's in the large round housing, at the rear of the car, in between the two rear wheels... you can't miss it - the driveshaft runs from the transmission to the rear diff housing.
Old Sep 29, 2004 | 08:29 PM
Texas240's Avatar
http://auto.howstuffworks.com/differential.htm
know how it works before you crack the case, get the FACTORY service manual. not a haynes. they suck
x.x i can't believe you've pulled a drive shaft & don't know what the differential is. see if there's a leak coming out of the 'pumpkin' where the 'bar' that goes to your wheels meets the driveshaft... you might just be low on diff fluid.
...serioiusly. DO SOME RESEARCH.
********** has an FAQ section. read it. all of it. it's got detailed how-to's. so do we here, just put 'diff' or 'differential' or 'diff*' and after enough searching. you'll find it. be willing to do some legwork & we'll be willing to help you.
Old Sep 29, 2004 | 09:43 PM
240sx 5spd's Avatar
thanks guys. is there anywhere on the internet where i can find a free copy of the FACTORY service manual
Old Sep 30, 2004 | 10:38 AM
For a 93, not a 92. But there were no changes between the years. Give me your email addy and I will send the page to you via email
Old Oct 2, 2004 | 03:01 PM
240sx 5spd's Avatar
thanks HyJnX my e-mail is xpbartoncore@comcast.net. let me know when you sent it
Old Oct 2, 2004 | 05:56 PM
Email sent!
Old Oct 2, 2004 | 06:00 PM
240sx 5spd's Avatar
thanks man
Old Oct 2, 2004 | 06:04 PM
240sx 5spd's Avatar
just check my e-mail and not seeing it
Old Oct 2, 2004 | 06:05 PM
Check again
