speed sensor!!!!
Old Nov 19, 2005 | 01:26 PM
bs280's Avatar
Angry speed sensor!!!!
ok i have a problem the speed sensor on the tranny is there but it had been cut so there are no wires coming from the engine so i have no idea where the plug is or where the wire goes. does any one know where the wire from it goes or what it plugs into i know its a light green and a black wire but i looked everywhere and i cant find it. Is there a way i can rought it off the ecu or the dash plug wires wires and splice it onto the sensor. I need all the help i can get so if somone knows can you help me out thanks
Old Nov 20, 2005 | 08:24 AM
2fast4y0u's Avatar
i will have my car back in a few days and i can help you out.
Old Nov 20, 2005 | 12:37 PM
bs280's Avatar
ok thanks
Old Nov 21, 2005 | 06:31 AM
Joel SX's Avatar
the wire its the colors you described. If you can't find it in the engine, its because its no there, its in the transmission. Its all the way in the back, before the driveshaft. Its rounded and has two cables going out. If you find it follow the wires up and see where they were cut, and so on. If you spedo works in your car, then you can jack the signal from it to your ECU. The cable that goes to the sensor comes from a harness that comes out of the right side of the car, looking at it from the back. Its right next to the battery. there's the engine harness and there's the transmission harness. from there you should see the cables that go down. they clip to the body of the car and separate underneath the fuel filter. the one for the speedo breaks away here, and goes out by itself. Its wraped in a black tubing. you should be able to find the color wires on the top of the harness right next to the battery. If you see any wires cut up here in the battery, those might be it. I'm pretty sure the cables are still here so you won't need to look under the dash or anything. If you can't find them there or on the harness, I have the complete engine wiring diagrams as well as connector locations so I'll send u a pic with them. good luck
Old Nov 21, 2005 | 06:44 AM
Joel SX's Avatar
In fact here ya go, the first one is the conector locations and numbers. The conector you see tells you where it ends, when yo usee it, remember that it ends there, then it conects to the speend sensor wires and goes further down to it.
Old Nov 21, 2005 | 06:46 AM
Joel SX's Avatar
This one is the wiring diagrams. you can see where the cables come from and the colors. you can see that it conects to connector 211 which is in the previus picture. hope it helps.
Old Nov 21, 2005 | 01:25 PM
bs280's Avatar
the wires on the speed sensor are cut so i wont be able to source them up from the tranny to the engine bay but the stuff you gave me might help me out thanks alot
tallic_red240sx
Sep 4, 2006 10:33 AM
cleanblk240sx
Oct 8, 2005 03:33 PM
NismoKa
Sep 9, 2004 06:40 PM
Matt_240
Apr 22, 2003 06:59 PM
