stock vlsd fluid
Old Mar 1, 2006 | 09:54 PM
Jovan's Avatar
stock vlsd fluid
Hey, what do you guys put in your stock VLSD? I searched but i only found what is used the the kaaz 2 way. I just got a zenkse and the guy said that he didn't put the right diff fluid in so i NEED to change it to the right stuff. What is the best weight all around to use in there? Thanks guys...
Old Mar 1, 2006 | 11:58 PM
i used the lucas gear oil fluid from advance auto, it works for for the vlsd.
Old Mar 2, 2006 | 12:25 AM
re037's Avatar
redline gear oil, oem reccomended weight which is 75w90, tho some ppl use 80w140
www.myoilshop.com
Old Mar 2, 2006 | 05:50 AM
Jovan's Avatar
Cool, but what's the difference in the two weights?
Old Mar 2, 2006 | 11:26 PM
re037's Avatar
i believe 80w140 is thicker. ive read that our 5 speeds feels smoother with thicker oil to absorb shock and what not. not sure about the diff tho. ill give it a try next time i change the diff fluid.
Old Mar 3, 2006 | 07:28 AM
Jovan's Avatar
Yea, that's sounds like the better choice of the two. Does the weight have any significant impact if any on the way it locks?
Old Mar 3, 2006 | 08:47 AM
Jovan's Avatar
Oh and what about synthetics? yes/no?
Old Mar 4, 2006 | 11:09 PM
LA_phantom_240's Avatar
Synthetic > petro base
royal purple owns all other fluids. period.
Old Mar 5, 2006 | 04:12 AM
Jovan's Avatar
What makes royal purple the best?
Old Mar 5, 2006 | 02:08 PM
Because it is made to very high standards. Royal purple makes jsut about every fluid for a car. Their oils have been tested to help gas mileage (probably only like 1mpg or so) and help reduce friction and drag in the motor (probably about another 1 hp). They are more expensive than other fluids, but its well worth the investment.
Joshkl
Feb 18, 2011 07:40 AM
onesloweg5
May 22, 2006 05:30 PM
BAKERrps13
Aug 7, 2005 12:40 PM
bw54867
Mar 18, 2005 06:47 PM
