stupid question from noob
ok so i took my diff off the car, took the cover off cleaned the gears of oil and started welding them.... and it caught on fire lol apperently i didnt get all the oil out. so i went to take the gears outta the pumpkin and cant figure out how they come out. someone please help. i've taken the berings off and cant see how the axles come appart
ok nm i figured it out
make sure you know what your doing with the welds, dont want it to break on you down the road.
yeah i made 8 tacks on the gears together and when it gets warm out ima finish welding em
yeah if they break on you it will lock your rear end up sending you spinning out of control.
that oil is nasty
make sure you know how to put it back in, you know you cant just stick it in right?
yeah i have a good idea. cept what do i torque the bearing caps down to?
65-72 lbs.
tkx
yeah if they break on you it will lock your rear end up sending you spinning out of control.[/B] |
