tranny problems(movie)
Old May 14, 2006 | 06:28 PM
alilvietboi4u's Avatar
car is getting worse. now 100 percent of the time it grinds instead of 80 percent....
below is a recording of what happening...(quicktime 7)
click here
anyone know what the problem is?
Old May 14, 2006 | 08:52 PM
sounds like sincro, had it gradually gotten worse? I would say check the tranny and make sure you got full fluid and are not leaking any, perhaps take it out and inspect the clutch...maybe the throwout bearing is shot..
Old May 14, 2006 | 11:28 PM
yep when i got the car a year ago i could shift into 1st at 15mph with no problems. it gradually got worse... =/
Old May 14, 2006 | 11:33 PM
i duno, if u dont wana take the tranny out maybe let a shop listen to it, they shouldnt charge you for that and see what they have to say.
Old May 16, 2006 | 10:40 PM
Jack0423's Avatar
I had the same issue with my clutch pedal and replaced the clutch and flywheel and the problem went away. the grinding sounds like another issue since mine never did that, check the master and slave cylinders as well; there may not be enough pressure to make the clutch work properly.
Old May 17, 2006 | 12:01 AM
The other week my clutch pedal, when pushed down, would do that where it would only come up a little and I'd have to pull it up the rest of the way. If I'd tap the pedal quickly it would come up, if I held the pedal down for a few seconds it would stick. My problem was a shot clutch master cylinder.
Old Jun 3, 2006 | 12:16 AM
Joel SX's Avatar
Defenetly the fluid in the line, or something with the clutch. b/c if you get it into gear, and once it comes out, it grinds again, the clutch is not disengaging. So thats prolly it. Lift it, put it into gear and wihtou lettign the clutch go down, see if the tires move, if the ydo, its not disengaging right.
Old Jun 3, 2006 | 02:18 PM
xpcgamer's Avatar
Sounds like what people where discribeing with the clutch dampning system in. I would overhaul the out side first. Remove the dampning system first,then work backwards. Slave, Master.
Supranatural
Sep 6, 2004 03:36 PM
Jedi Mind Gamez
Aug 20, 2004 12:36 AM
bullheadd1nismo
Jul 18, 2004 01:52 AM
bullheadd1nismo
Jul 15, 2004 03:43 AM
war
May 28, 2004 09:30 PM
