transmission question
Old Apr 13, 2006 | 04:55 PM
sbanzer123's Avatar
i was taking out my transmission today to put a new clutch in. does anybody know what what the clip is for on the very top of the bellhousing, i think its either the knock sensor or the crank pos sesor. also when pulling the transmission do you have to loosen the back motor mounts to get the bellhousing through the transmission tunnel? im having a problem getting the transmission out. its all disconnected and slid mostly out but icant get the transmission all the way out. any suggestions will be appriciated. thank you.
Old Apr 14, 2006 | 01:00 AM
Is the shifter clearing the hole on the inside of the car? Just look and see if its catching anything...which back motor mounts? Theres only two motor mounts and one transmission mount. I believe the reverse sensor is near the top of the bellhousing.
Moved to "Drivetrain"
Old Apr 27, 2006 | 07:55 AM
Joel SX's Avatar
on top of the bellhousign there's the "cam angle sensor" unlike the "cam position sensor" which is inside the distributor.
91240SXGuy
Jul 8, 2007 01:16 AM
gerbort
Mar 23, 2004 07:14 PM
malicex000
Dec 12, 2002 09:30 AM
anttoni
Dec 6, 2002 04:01 PM
rEvVoMaNiAc
Sep 27, 2002 12:56 PM
