ughhh omg new clutch and preasure plate and i'm having problems
I have installed a new clutch, new preasue.. then i bled the master and slave cylinder with dot 3 break fluid and did not work.. my car stuck to the floor and never comes back on its own... so i said to myself okay the my master and slave cylinder are shot.. so i replaced them.. so with new master and slave cylinder in.. i bled again with dot 3 break fluid and still the clutch is not building any preasure up and is sticking to the floor.... now what do i do? i been stuck with this problem for a week now....ohh and my doesn't wanna go into gear with the car turned on but car turned off goes into gear fine.. i'm really confuused... i read about this damper box thing but i didn't really understand it so i didn't wanna mess with it.. any ideas???
**** so i'm using wrong break fluid cuz i'm using dot 3.... would that **** up my master and slave cylinder if i used the wrong stuff?.. okay i'm gonna try dot 4 tomorrow.. just let me know if my master and slave cylinder are still okay? from using wrong fluid?
bypass the damper box!!!
u see where the hardline coming from the master cylinder into the damper box?...
well what you want to do is instead of it going into the damper box, have it go straight into the slave cylinder, so you may have to rig some kind of hardline, or get braided hoses or something
the damper box makes bleeding nearly impossible without having a pressure bleeder
well that is pretty much what you're problem is
good luck with it
good luck with it
and doing this will bring preasure back into my clutch and it'll go into gear again.. so i can drive off?? LOL i haven't drove in a month from going this damn clutch swap and having problems with the lines.
it is my understanding that you can use DOT3 in the clutch lines...
think about it, DOT3 is for brakes, which have to take high heat and very high pressures without breaking down. the components in the clutch master and slave are metal, just like brakes.
and even if I'm wrong, I dont care, cause mine works just fine with DOT3
thanks everyone no more damper box and the car is fixed now.. now i gotta get my engine fix before it blows. lol well it wont blow as long has i dont race around all day and change the oil every 2 weeks. keep doing that should be good til i find out what the heck is wrong?
If u want to bypass the damper box, TAKA MOTORSPORTS sells the bypass line for like 30 bux. www.takamotorsports.com. Hooks right up. Makes it a hell of alot easier to bleed the clutch lines
