z32 lsd?'s
Old Aug 12, 2003 | 05:22 PM
needasr20's Avatar
z32 lsd?'s
ok what do i need to install this lsd i hear it works.. do i need a different driveshaft.. axles anything .. how hard is it do i have to take the pumkin apart.. do i get a 5 lug conversion also for the axles and about how much.. i am sure my next item of purchase is an lsd so i just need some help thanks
Old Aug 12, 2003 | 07:14 PM
StanBo's Avatar
What LSD are we installing here?
Old Aug 12, 2003 | 07:37 PM
needasr20's Avatar
just the one out of the 300zx i guess z32.. sorry i'm stupid are the different ones or do you mean like the oem or aftermarket.. i mean oem peace
Old Aug 12, 2003 | 07:45 PM
StanBo's Avatar
Nah I am just trying to tailor my answer to your question instead of just rambling facts and figures.
Z32
J30
180sx
240sx Hicas
Those are some of the VLSDs you can use.
Their coding is 200V for the pumkin.
When researching look out for the bolt pattern on the output shafts.
You have a 6 bolt pattern now and some of these (if not all) have a 5 bolt pattern. If they do you will either need the axles or the output shafts.
I have also included a search on our friend the VLSD here. So get to fact checking.
Old Aug 12, 2003 | 07:50 PM
needasr20's Avatar
super pimp.. my lsd research has started.. i'm prolly just lookin for the easiest one to put in in that case i cant afford new axles most likely or anything kool like that anyways thanks i'll be readin for a while peace
Old Aug 15, 2003 | 03:02 PM
needasr20's Avatar
ok found a 90 300zx vlsd.. thats z32 still.. the output shafts are where the axle hook up (i think , this is all sorta a ?) so it will hook up to my driveshaft just fine right?? tell me if i'm all right .. this is the link to the vlsd if anyone that knows whats to point out sumthin bad ..
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427810680
Old Aug 16, 2003 | 06:34 AM
StanBo's Avatar
It will connect to your driveshaft fine.
You will not be able to use your current axles with that pumkin.
It is a 5 point output shaft while yours is a 3 point double connection ouput shaft.
WILDACEXXX
Jun 29, 2007 09:14 AM
rancidnsx
Sep 27, 2006 02:16 PM
struck1
Dec 7, 2005 05:13 AM
boostevolution
Nov 7, 2004 04:46 PM
badman70_1
16
Mar 1, 2004 08:02 AM
