97-98 Auto To Manual Swap
WHAT DO I NEED PARTS WISE TO DO THE SWAP AND HOW MUCH DOES EVERYTHING RUN. I JUST BOUGTH MY KOUKI BUT I DON'T LIKE THE AUTO MY LAST CAR WAS MANUAL AND I MISS IT ALREADY.PLEASE HELP. OR SHOULD I JUST BEAR WITH IT AND WAIT UNTIL I AHVE ENOUGH TO DO THE SRDET20 SWAP??
INPUT PLEASE, THANKS |
just wait until you do the swap...that way you get a manula trans
parts you will need clutch pedal set manual ecu slave cylinder clutch master cylinder all fluid lines required shift boot and shifter bezel manual transmission crossmember manual tranny mount |
Originally posted by 2fast4y0u just wait until you do the swap...that way you get a manula trans parts you will need clutch pedal set manual ecu slave cylinder clutch master cylinder all fluid lines required shift boot and shifter bezel manual transmission crossmember manual tranny mount Brake pedal (they are different) Oh and DONT POST IN CAPS IT ANNOYING. GO TO YOUR LOCAL MECHANIC TO SEE WHAT THE PRICE WOULD BE. SEARCH FUNCTION DOES WONDERS. |
Werd /\
*this should be asked in drivetrain*
dont forget the manual driveshaft
And don't forget to press "caps lock", and turn it off. Good luck.
you actually dont need the whole drive shaft. u just need the piece that connects the drive shaft to the trans...thats what is different length. but get the whole thing so there is no problems
